I'm finally building my door this weekend, and am wanting to make it cheap as possible after going overbudget on the over(surprise)
I've got some 1/4 sheet steel I plan on using for the inner and outer door plates, and some thinner stuff to use to close it.
I plan on making it 3 1/2 inches thick, (3" between doors + 1/2 inch of steel).
I was going to use leftover loose perlite to fill it, but alas, the outer p-crete layer took ever last crumb I had.
So my questions are thus:
What should I use to insulate the inside, since I have no leftover perlite or ceramic blanket? Is there a noticeable difference in insulation characteristics, or is whatever I can get cheapest work?
What do I need for a gasket? Does self-sticking stuff similar to this:
https://www.amazon.com/dp/B0190YY796?psc=1
work? Or should I get something else?
Finally, I plan on putting a thermometer in the over door, just so I can more easily see the temp the day after. Is there anything special about the forno bravo thermometer, would it work (at least temporarily) to just use an old meat-type thermometer I have with a 4" probe (goes up to 700)?
