Where can I get foam glass in Massachusetts? I have decided to use it under my CFB.
My intention is to use full brick as the first "soldier" course around the perimeter. These bricks will also be sitting on top of the fiberboard
I have acquired some tapered brick which will alternate with straight brick as the courses come up. See cross-section pic. any comments on this approach? Will use a lot less mortar and no need for pegs/wedges
Considering drilling a few holes through the concrete underneath the hearth as a precaution to allow any water/moisture buildup of a way out
I appreciate any and all feedback. Thank you
David G
David G
