Homebrew question..
  • Chach
    • Mar 2018
    • 635
    #16
    Originally posted by Johno4
    The local lime I finally found was $11 and change. I ended up getting fire clay from the ceramics store, $17 for 50lbs. $50 for 50 lbs seems high for clay
    I thought so to I found it at a ceramic store for $15.85 for 50lbs
    My Build Pictures
      • 3885
      #17
      Hi Johno4,
      Sorry for the late reply. I'm glad that you found the hydrated lime. In answer to your op: In most cases the answer is no. Type-N masonry cement can't always be substituted for the Porland cement and lime. Although, the original recipe for Type-N masonry cement is 50% Portland and 50% hydrated lime, the manufacturers are allowed to substitute the lime with "the equivalent". That usually means some lime, some crushed limestone, and other proprietary additives. There are still a few small companies that make it from the original recipe but, very few. The old brick layers that preferred it (due to it's workability) have about all died out. The current generation of brick layers prefer the altered recipe because it is much less corrosive to the skin.
      When I was a young brick layer's helper for my uncle, we would sometimes use premixed Type-N and at other times make it from scratch. I did not fully understand it at the time. Along with other brick jobs, we built fireplace boxes and brick BBQ's. We would sometimes go back and do repairs on old fireboxes. That usually meant just repointing the joints on a 30 year old fire box. The mortar would erode over time, but the firebrick would generally be in good shape. A 30 year old firebox today that was layed with the modern mortar will have substantial brick damage. Imo, the crushed limestone will swell when heated causing the faces to pop off the firebrick
      When I first joined the forum, I would have told you that you could use any Type-N masonry cement to replace the Portland/Lime parts of the "home brew". Then, Tscarborough schooled me on modern masonry mortars.So, here I am, passing on the information that I have learned on the forum. I wanted to reply to this just in case someone else researches this question.
      • Johno4
        • Feb 2019
        • 11
        #18
        Thats pretty much the conclusion I came to as well. Although quickrete would not give me an straight answer on if it was portland and lime, they did say it is an equivalent and can be used the same as portland and lime. It is a little annoying that they cant simply tell you what is in what they expect you to buy. Oh well, I can mix my own when the time comes. I am hoping to start my build in a month or so when the weather here breaks.
        John
