I found powdered fire clay at a mason supply store near me and it was $65 for 50lb bags. I also found powdwred fire clay at a pottery ceramic supply store and it was $16 for 50lbs. Obviously the mason supply store is the correct fire clay no doubt, but is there a difference in the cermic pottery store fire clay? Its called Hawthorn Bond and here is the link to the cut sheet https://www.google.com/url?sa=t&sour...3vEnGSDGv8ZXhs It talks about mesh which I assume is the finess of the powder? I obviously would rather get it cheaper as long as it works correctly for me.
Tags: None
The ceramics store clay will be fine. It’s shrinkage rate is not excessive. Actually any powdered clay should be suitable for the temperatures we fire to except Bentonite which has extremely small particle size resulting in too much shrinkage.Kindled with zeal and fired with passion.
Great Thanks for clearing that upMy Build Pictures
I have located type S hydrated lime at home depot but it says in the package it contains portland. I have attached the link to it below. should it have portland in it?
My Build Pictures
No, it should not. From the link, I can't find where it says that it contains "portland"? I see in the product overview that it "can be blended with portland to make masonry cement". Which is true.Last edited by Gulf; 02-24-2019, 11:30 AM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
The link that you provided is for Type S Hydrated lime. That is what you want for the home brew. However, after going back to the first part of your postbut it says in the package it contains portlandJoe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Originally posted by Gulf View PostThe link that you provided is for Type S Hydrated lime. That is what you want for the home brew. However, after going back to the first part of your post Is it possible that you were looking at a bag of Type S Masonry Cement while in the store?My Build Pictures
Read the bottom left corner of the bag pictured here1 PhotoMy Build Pictures
I stand corrected. The labeling by Quikrete is misleading. Type S Hydrated lime should have no portland in it. So, I'm guessing that it is a portland/lme masonry cement. To be Type S Masonry Cement, the mix will be 1 part lime and 2 parts portland cement and should be labeled as a cement imo.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
yeah total deception....My Build Pictures
I ask a quesrion to home depot i will send an email to quickcrete nextMy Build Pictures
Quickrete answered both my questions through the home depot website. They told me there is no portland in the product and then i asked why does the bag say it does. Quickrete's response was the graphic on Home Depot's website is inaccurate and the hydrated lime contains no portland. So I guess that solved that question. Here is the link to the questions I asked and the manufacturer's response.
My Build Pictures
- Likes 1
Great catch on reading the labeling for the graphic. You also did a great job doing the leg work with Quikrete to clear this up. As of my post, the misleading graphic is still up on Homer's website.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Originally posted by Gulf View PostGreat catch on reading the labeling for the graphic. You also did a great job doing the leg work with Quikrete to clear this up. As of my post, the misleading graphic is still up on Homer's website.
RickyMy Build Pictures
