Central NJ - Looking for refractory mortar/fireclay
  • Central NJ - Looking for refractory mortar/fireclay
    Hey guys, I can't seem to find something appropriate to work on the dome. I would prefer to make the homebrew mortar but can't find fireclay anywhere. I'm wondering if something like this refractory mortar would work just as well? https://www.homedepot.com/p/Rutland-...-211/300981819 .
    Thanks!
    EDIT: Maybe it's best to buy FB's refractory mortar ?
    I would check pottery stores for the fire clay your going to need a lot of mortar you would use that bucket in no time.
    My Build Pictures
      try this place http://shop.ceramicsupplyinc.com/hawthorne.aspx they have hawthorn bond. I'm not sure how far this is from you
      My Build Pictures
        Thanks, I'll check it out. Does anyone know how hot the homebrew can get, am I better off spending a little extra money and buying the FB premix and avoiding the uncertainty?
          Home brew 3:1:1:1 (sand, lime, portland, fire clay) has been used by hundreds of FB forum members and works just fine for the normal temps of a WFO. FYI, fire clay or brickies clay can be obtained at most masonry suppliers which will be quite a bit less than a ceramics store. Sometimes the big box stores carry it too, but not too often. You will go through a lot of mortar so commercial refractory will be quite expensive.
            In my area clay at a mason supplier was $50 for 50lbs very exspensive and $15 for 50lbs at a ceramic store...you have to shop around as it may be differemt in different areas but the store link i gave you was $16 for 50 lbs. For how much mortar these things use I'd say use the homebrew totaly worth it
            My Build Pictures
              Good idea. Thanks for the feedback!
