Hello,
in the next weeks I’ll start to build the dome of my wood fired oven. I’ve three questions, that remain:
Question 1: I’ve read a lot about the refractory mortar but the more I read, the more I get confused. I also asked three suppliers of mortar what is the right product, as the translation to German is not clearly. Could someone give me an advice, which is the best product to use for building the dome?
Supplier A:
I should use „Schamottemörtel“ mixed with 10 % portland cement at the inner joints where they are not larger than 3 mm. The „Schamottemörtel“ only sets ceramic at about 800 C, but with the 10% Portland cement it sets hydraulic at normal temperatures. The „Schamottemörtel“ has the following specs: Al2O3 (38 %) / SiO2 (2,3 %) / no Fe2O3 / no CaO. Temp: 1450 C.
(Google Translator: Schamottemörtel = fireclay mortar)
For the outer joints larger than 3 mm I should use „Feuerfeste Reparaturmasse“. It sets hydraulic at normal temperatures. The specs are: Al2O3 (50 %) / SiO2 (41 %) / Fe2O3 (1,8 %) / CaO (4,9 %). Temp: 1450 C.
(Google Translator: feuerfeste Reparaturmasse = refractory repair compound)
Supplier B:
I should use „Feuerzement hydraulisch“ which sets hydraulic at normal temperatures as the only mortar. The specs are: Al2O3 (48 % - min 43 %) / Fe2O3 (3,6 % - max 4 %) / SiO2 (40 % - min 38 %) / CaO (9 % - max 11 %). Temp: 1350 C.
(Google Translator: Feuerzement hydraulisch - fire cement hydraulic).
Supplier C:
I should use „Schamottemörtel Monolith E“ which sets hydraulic at normal temperatures and ceramic at about 800 C as the only mortar. The specs are: Al2O3 (35 %) / the supplier does not know the other ingredients. Temp: 1250 C.
(Google Translator: Schamottemörtel Monolith E = fireclay mortar Monolith E)
Homebrew:
Or is it better to use the homebrew recipe? I’m very unsure there about the 3:1:1:1 mixture. Is it volume or weight based? What lime to use? What exactly is fireclay? In Germany firebricks are called „Schamottesteine“ and there is a product called „Schamottemehl“ which seems to be the powder of these bricks…
Question 2: Supplier A stated that I should should use a product called Ölpapier (= oilpaper) in Germany. I should use it as a separating layer between the ceramic blanket and the vermiculite/Portland cement layer in my build. It should protect the blanket from the humidity of the cement. Does that make sense or is it a wrong information?
Question 3: I read somewhere that I do not have to mortar the first circle of bricks of the dome to the calcium silicate board. Only brick to brick (left-right). The second circle and the following circles are then mortared to the one below. Is that right? I can’t find that information again…
Thanks for your help! It’s so confusing :-)
Jens
Supplier A:
Supplier B:
Supplier C:
Homebrew:
Jens
