Greetings all! My first thread here, I have to start by saying what a great community this is, full of knowledge and enthusiasm! Thanks for being here and I hope one day to contribute myself
In the meantime, my journey to build a 39” Pompeii dome oven is just beginning - with building materials. My local supplier is having supply issues with 2” fibreboard, and has instead offered 2x the qty in 1”. They have kindly given me the option of taking the 1” boards now for the same price or waiting until the 2” is available.
Apart from the slight hassle of cutting twice as many bits of fibreboard to shape, and staggering more joints, are there any downsides? Or indeed as the title suggests, is it even reasonable to expect marginally better insulation from several layers? Is it ok to separate the layers with foil?
Thanks in advance!
Thanks in advance!
A couple layers of 1" CalSil board (to give you at least 2" total thickness) is considered the basic amount of insulation for a WFO. Many builders add more insulation by laying the CalSil on top of either FoamGlas or 5:1 insulated cement (either perlite, vermiculite, or a mix of the two with 1 part by volume cement). You won't get better insulation value having two layers with overlapped seams vs a single thick layer, but the difference is negligible. It's the total amount of insulation thickness that matters, not how many layers it takes to achieve that thickness.
