Hello,
I've gotten to the point in my oven construction where I'm looking at render mixes for the dome. The dome is cast refractory and will be covered with 2" of Forno Bravo's version of Kaowool with either chicken wire or construction cloth over that.
1a) I see people using perlcrete as a base render. What does perlcrete provide that a straight render does not?
1b) What is the mixing ratio for perlcrete as a rendering layer?
2) What is the mixing ratio that is used for the non-perlcrete render?
3) I live in northwest Wyoming where humidity is almost always low and we receive little snow in the winter (generally). What kind of waterproofing is or isn't recommended either as an addition to the render or as a finish coating?
I did a lot of searching on the forums to answer these questions and found a variety of answers and am hoping to be able to narrow the answers down to a few definitive ones. I have to drive 100 miles to get to a Home Depot or larger suppliers of masonry materials so making one run with all of the materials I need will be beneficial lol.
TIA
TIA
