I'm only referring to bolts/nuts/screws used to hold custom peels to their handles or possibly to close and hold together a door. The peels and door will primarily be either steel or aluminum of course.
So the brass I'm referring to is small (just bolts) and in the case of peels (but not the door) won't be exposed for long durations.
Since brass is a zinc alloy, I'm unsure whether it is to be avoided for the standard no-zinc reasons.
Thoughts?
Thoughts?
