Fire clay Mortar Vs Refractor Mortar FB.... HeatStop... Earthcore
  • 100million
    • Feb 2010
    • 141
    I am wondering about .....What motar can i use for my fire brick pizza oven?
    What is the differance between Refractory mortar (premix) like FB or Heat Stop Drymix and the lower cost modified portland cement fire clay sand and lime mix?
    Is the Premix for use with fire brick ovens the same the modified?
    Are they both the same strength when used between the fire brick?
    Has anyone heard of Earthcore Mortar used with ISOKern fireplaces modular systems.. Earthcore Industries, Inc. - Mortar
  • Les
    • Sep 2005
    • 2945
    Re: Fire clay Mortar Vs Refractor Mortar FB.... HeatStop... Earthcore
    The Ref Mix and Heat Stop are top of the line, easy to work with and is diamond hard when dried. Many have used the "roll your own" with great results. I have used all three. I think it comes down to your wallet. I have never heard of the Earthcore product, but if it's for refractory builds, it will most likely work (unless it is made up of nasty stuff).
    Les...
    • kebwi
      • Aug 2009
      • 1090
      As with many others here, I used the "homebrew": silica sand, fireclay, portland, and lime (3:2:1:1). Working great for me, although I would recommend a smaller sand grain size than the #30 I used. Finer sand would produce a mortar that would spread more evenly in the tighter joints.
      • Raffy
        • Sep 2008
        • 213
        Hi All,
        I've just used a fireclay mortar with the generic name of sk32 mortar. I'm kinda worried that this mortar will not be able to stand up to the task when it comes to the dome and arch design of a pompeii oven. I just applied it to a few bricks and it still hasn't set after 3 hours. It doesn't set like cement and has a clay consistency. I called the people who sold me this bag and they said it should have set already in a few minutes. I mixed up a batch and bonded two bricks together and I'll test out its strength after it has cured properly but i don't want my current work to be for nothing if a week from now I discover that this SK32 Mortar is crap.
        I'm a total stranger to mortar and its characteristics so is this normal for a fireclay mortar. Should mortar only be used as a thinset? Sorry if I sound desperate but I'm freaking out cause I've never really worked with mortar and I'm used to the immediate hardening of cement once it has set.
        Raffy
        sigpic
        Raffy's WFO Build Thread
        WFO Build Pics (Picasa)
        • Raffy
          • Sep 2008
          • 213
          Is fireclay the same as fireclay mortar? My confusion stems from the fact that the people I bought the fireclay from said that the fireclay mortar is all I need. They instructed just to add water and apply. Should I use this SK 32 Mortar by itself or combine it with lime cement and sand in the home brew high heat mortar.
          sigpic
            No. Fireclay is a powdered clay with heat resistant qualities. You can build your dome with a fireclay/sand mixture, as Frances did, but it's not waterproof.
            Our homebrew mortar uses fireclay as one ingredient. I don't know what "fireclay mortar" is, in the context you are using the term.
            I googled SK 32 mortar, and found no information, except for a couple of Indian and Chinese exporters listing it among the products they sell.
            Sorry I can't be of more help.
            • Raffy
              • Sep 2008
              • 213
              Hi Dmun,
              I guess a better way to rephrase the question is can fireclay by itself be made into a mortar if not then I guess its safe to assume that this SK32 Fireclay Mortar that these exporters are selling already contains additives that will help bond bricks and other refractories together. I asked around and I found out that SK refers to heat capacity. So, as the SK number rises SK32, SK34, SK36... so does the max temp. My firebrick is graded SK32.
              Another question springs to mind, could it be that SK32 Fireclay Mortar is in fact an airset mortar which only strengthens when it is fired? If thats the case I'm better off with the homebrew since I can't use airset in an outdoor setting. Boy, am I confused.
              Need to research this fireclay thing more thoroughly. Sigh...
              Raffy
              sigpic
              • james
                Brick Oven Merchant
                • Mar 2005
                • 4648
                In layman's terms, mortar requires a binder and aggregate/additives. The binder causes the chemical reaction that transforms the mix of binder and aggregate into a material that hardens and cure.
                With the home-brew mortar, Portland cement is the binder, and sand, fire clay and lime are the aggregates and additives. Fire clay gives the mix a little bit of resistance to thermal cycling, while the lime makes it sticky and workable. But without Portland cement, it will not set and become hard and waterproof.
                With a refractory mortar (such as FB Mortar), the binder is calcium aluminate and the aggregate is a composition of refractory (heat and thermal cycling resistant) materials. There are also additives the make it sticky and that help it harden a little faster.
                I cannot tell from you description what you product is -- though I can confirm that the SK terminology does have to do with the composition of materials (it also applies to firebricks).
                I hope this helps a little.
                • berryst
                  • Jun 2008
                  • 184
                  I used lime, clay, sand, and portland cement. My major concern was spalling. To date, after a couple of years use no spalling has occured.
                  I would use it again.
                  berryst
                  sigpic
                  • Raffy
                    • Sep 2008
                    • 213
                    This helps a lot, James. I'm beginning to suspect that this mortar is "activated" by heat. There doesnt seem to be any binder of sorts cause it doesnt harden. In fact, I went out to check it this morning and it seems to have softened. Maybe the moisture of the early morning air softened it.
                    I'm not sure this company knows its terminology but SK32 mortar doesnt really bind like a mortar or harden at all. Maybe SK32 Mortar is simply fireclay... but that doesn't explain why they would say just add water. Sorry just thinking out loud.
                    Anyway, thanks for the help, James. Based on your reply, I wont be using this product on its own. If in fact it is just ordinary fireclay and not a SK32 Mortar as they have labeled it then I'll use it for the homebrew.
                    sigpic
                    • Raffy
                      • Sep 2008
                      • 213
                      berryst
                      Is that just ordinary clay that you used for the homebrew? If so, I may have to do it your way just in case I can't find fireclay.
                      sigpic
                      • pduany
                        • Feb 2010
                        • 12
                        I understand cost is the big driver for this choice. What are we looking at for the difference? I know material costs very by region but some examples of how much mortar we would be looking,, at what it cost people would be helpful thanks
                        Patrick
                        "It is never to late for a happy childhood"
                        -Robin Williams
                        • eprante
                          • May 2009
                          • 282
                          As to the cost question, the homebrew is much more cost efficient. The refractory mortar usually runs about $55.00 per 50# bag and most people have said that they use 4-5 bags. For the cost of 1 bag of HeatStop 50 you can make all the homebrew you need to assemble your dome. I am using the homebrew recipe and find it easy to work with. I went with the homebrew because many people had used it on this site without problems.
                          Raffy, I have heard fireclay referred to as mortarclay ( actually I have a bag of mortar clay) I think what you may have is straight fireclay.
                          Eric
                          • ThisOldGarageNJ
                            • 1436
                            Hi Raffy,,
                            Is it possible to call the company to get an MSDS ? Material Safety Data Sheet That will give you a list of all the ingredients in the product and any dangers and such... Then you may know how to proceed with it....
                            Mark
                            • Raffy
                              • Sep 2008
                              • 213
                              Originally posted by ThisOldGarageNJ
                              Hi Raffy,,
                              Mark
                              Good idea. I'll call them first thing on Monday then I'll post the ingredients and maybe you can tell me if this is just ordinary fireclay or if it has some other additives that will cause it to set. Thanks, Mark.
                              Oh, and by the way, would love to have your comments on my latest progress which I posted on my WFO build thread. I'd really appreciate your insight.
                              Warm Regards,
                              Raffy
                              sigpic
