Warning!
Gas fired pizza ovens use high heat and combustible fuels that if not properly installed and maintained can lead to explosion, fire, injury, or death. By utilizing this site and the information given, you agree to our General Disclaimer.
Propane pre-heating in WFO??? Possible or crazy?
    This question should be directed to a license professional, city inspector, or local gas provider as per the Forum disclaimer. I removed the direct hyperlink to the flame failure device.
  • w650gb500
    Can someone point me toward a devise that would work with my set-up. Thanks.
    Would this work? Click image for larger version
    Last edited by UtahBeehiver; 11-23-2021, 07:34 PM. Reason: Removed the hyperlink but cut and pasted the item.
  • MarkJerling
    Ovens can be replaced. A handsome mug like yours, I'm not so sure . Seriously, don't use a device like this unattended. I use gas on one of my "throwed together" metal forges without any safety devices. I have had flame outs. But, I am there to immediately correct the problem! Propane will ignite at 920F to 1020F. Natural gas a little higher. WFO's will heat a projection of brick to those temperatures well before the oven is up to working temperature. It only takes a fuel source (gas), a slight draft of wind (O2), and the ignition temperature to cause a major problem!
    Thank you, and yes, 100% agreed. Without a reliable flame failure device I'd certainly not even try it.
    Originally posted by MarkJerling View Post
    Truth be told, I'd be more worried about all the flying bricks and my hard work gone than my face! I think the flame safety device is most important. Unfortunately, the one local firm that makes such a thing specifically for pizza ovens are out of stock and the wok burners with fail safe devices are very expensive, so I'll need to think about this some more to find an economical and safe solution.
    I'm glad you have acknowledged the lack of a flame failure device on your burner. Should the flame fail, the hot oven will fill with gas and relighting it becomes extremely dangerous. I didn't say you were using gas in conjunction with wood, just a warning that the combination is extremely dangerous if no flame failure device is fitted.
    FB did post this disclaimer about the issue.
    All advice, observations, instruction, recommendations, or other information (herein “Content”) provided on this forum are submitted by individuals and, if utilized, should be utilized with caution, discretion, and at your own risk. No Content constitutes advice or information endorsed by Forno Bravo, LLC. Forno
  • w650gb500
    Making up a homemade gas burner set up has been a taboo subject on this forum because of the safety aspect. I’m not sure of the current policy, but someone else may chime in. The burner should be fitted with a flame failure device (I don’t see one with your set up), as filling a hot oven with gas is a potentially dangerous situation. The problem is further compounded if wood is also used because it can provide an ignition source for unignited gas.
    I can appreciate your concern, but I ask you to go back through my posts and re-read all of them. I went through my entire procedure from honking it up to the tank, lighting it, inserting it into the oven, heating the oven, removing it and storing the assembly. You are stating things that simply aren’t true. Filling a hot oven with gas? Yes, if the flame goes out then it’s possible and I will look into a flame failure devise, but when or where did I make any mention of putting raw gas into a hot oven? Also, where did I state that I used gas and wood at the same time? I suggest a quick re-read so that nobody else misunderstands what I built and how it’s being used. I don’t want to start a disagreement but I don’t want someone taking something from this thread due to misinformation.
  • MarkJerling
    This topic has been approve subject to the Sticky forum disclaimer at the beginning of the topic.
    Cool! Thanks Russell.
  • MarkJerling
    Indoor or outdoor doesn't matter when your safety is of concern. An oven is a confined space where the collection of combustible gasses can occur..............with your face at the opening when they can ignite
    I am going to unapprove topic until we can get an consensus among the moderators and FB
  • MarkJerling
    No, a wok burner does not have a flame failure device attached as it is not designed to be used in an enclosed chamber.
    Here, all wok burners designed for indoor use must have a flame failure device, per AS/NZS 5263.1.1:2016. Outdoor use wok burners do not require a flame failure device.
    Taboo subject or not, I think I'm going to build one! Although, I may use a standard cast iron burner available here as a "wok" burner. As it would have all the fail safe devices all I'd need to do is add a steel pipe to extend the location of the regulator and hose to outside the oven.
  • MarkJerling
