I want to build an oven that can be self contained and moved around fairly easily and still cook a 9" pizza at the proper temps.
Here is what I'm thinking:
1. Cut an 18" steel pipe down to a 27" length
2. Cut the pipe lengthwise 3" over center
3. Weld a 1/4" plate to replace the cut off section in order to create basically a half cylinder shape
4. Line the bottom and top with standard 3" x 4.5" x 9" firebricks as illustrated in attached photo. It will take 39 bricks. (the bricks are cut and placed so that they cannot move, no mortar or securing is needed)
4. Weld a 1/4" plate on each end
5. Fabricate endplates for the front and rear (opening in front, sealed in rear)
6. Weld big handles on either side so two guys could carry it
7. Paint the outside with a high temp paint
I have attached a few images that may help to illustrate my idea.
The total outside dimensions would be 27" x 18" x 16".
What do you guys think?
Is it two small to work?
Does it need a chimney?
Does it need a door?
Would two guys be able to carry this 400 lb oven?
I would appreciate any input.
