floor insulation
  • sumu
    • Oct 2008
    • 100
    floor insulation
    can you use silica sand for the oven floor or is vermiculite a better choice.
    Re: floor insulation
    All together now:
    Sand is not an insulator
    Gravel is not an insulator
    Dirt is not an insulator
    Broken glass is not an insulator...
    is the verse, and the chorus is:
    Insulate! Insulate! Insulate!
    • RTflorida
      • Jan 2007
      • 1446
      Amen!
      stick with perlcrete (perlite & portland cement), vermicrete (vermiculite & portland cement), or the best option - ridgid refractory board insulation (commonly refered to as FB board - sold in the FB store as well as other brands at your local kiln or refractory supplier).
      USE NOTHING ELSE - you won't be happy with performance and will need a hardwood forest if you want to use it regularly.
      RT
