Flue dimensions
  • spt
    • Feb 2009
    • 25
    Flue dimensions
    Hi and sorry if this has been asked before but I am asking those who have completed a 36 inch dome oven 'What size flue did you use - 6 or 8 inch, and what length is it? Also, are you happy with the performance of smoke draw and if you could would you change it to a different size? Sorry for all the questions but I am trying to decide what flue size to use on my oven to achieve the best performance.
    Regards
    Dave
  • kebwi
    • Aug 2009
    • 1090
    Re: Flue dimensions
    36", 8", 4'. The excellent draw on my oven also benefits from what I consider to be a good smoke chamber design. Instead of a hole cut in the top of an otherwise unaltered arch, my arch and vent are shaped like an inverted funnel, with steep sloping sides and a vertical front and rear wall. The steep sides permit air (smoke) to "find its way" upward and the wall at the front acts as a barrier to smoke that would otherwise easily escape out the entrance.
    Check out my build thread or my website for zillions of photos of my arch and vent design.
    Cheers!
    • spt
      • Feb 2009
      • 25
      Re: Flue dimensions
      Hi Kebwi
      Thanks for the reply. Great photos on your website of your build - very neat brick work. I like your flue design and now regretting not tapering the first brick up on my build more, although the smoke chamber is a reasonable size which I will taper to the flue as it is being made out of stainless steel. I will more than likely go with the 8" flue.
      Appreciate the response.
      Regards
      Dave
