Hello,
I've been meaning to build an oven for quite some time, and I've finally started. Attached are pictures of the cinderblock stand that I've arranged. This weekend I plan to start with some irreversible portions of the building process, and I wanted to ask some questions before I make anything permanent.
1.) Home Depot being what it is, the palette of blocks that I purchased turned out to be made from what looks like two different molds, each with a slightly different length. To get things to line up properly, I've had to chisel the flanges off of a couple of the blocks to shorten them (you can see one in the picture of the void that is attached). The blocks I did this to seem to have come through alright, but could I have damaged them?
2.) Due to the varying cinderblock shapes, the voids that Forno Bravo instructs you to fill with cement are not lined up (picture below). They still seem to make a cohesive chamber. Is this OK?
3.) How important is it that the fourth course of cinderblocks be level? It doesn't seem very important (since it will be covered by the hearth), but I want to make sure before I pour cement into the voids.
4.) My local Home Depot does not carry 8x8 blocks, so I've been cracking 8x16's in two. Pictures below is one mistake I made. It's at the base of the stand, facing the inside of the chamber (so it won't be in sight when the oven is finished). Should I let this slide, or is it a structural issue?
5.) Finally, I was quoted well over $100 for a length of 2"x2"x3/8" angle iron. Venerated sirs, I submit to you that this pricing is balls lame. I was thinking about casting an archway to bridge the opening in the stand instead of using the angle iron approach, and I was thinking of doing it by making a more sophisticated mold for the hearth than what's in the FB instructions. In a nutshell, I would lay out all the cinderblocks I could, fill the voids with cement, and then construct a mold that encloses the hearth area and also a lintel over the opening (all of it reinforced with rebar). Is this s sane plan? Have other people done it?
Thanks for any advice you can offer!
