Hey guys this is my first post so HELLO! Got an idea, I have been researching all the different insulation materials (Super Isol, FB Board, Calcium Silicate Board, Vermiculite board etc.) available for installation under the medium (or low duty) firebrick floor and walls of my oven build.
I had an idea: why not place an insulating fire brick layer down under the 2 inches of FB board? This would lift the FB board off the concrete hearth by 2.5 inches allowing for the board to be more sheltered from possible moisture infiltration and allow the insulative fire brick to take the brunt of any moisture that may be able to infiltrate between hearth and insulation layer. The added bonus would be the additional insulation provided by the insulating fire brick at a fairly low cost.
The Fire Brick has a pretty high crush resistance: 1.5 Mpa (220 psi) and the FB is about .5 Mpa (72 psi)
So here is what it would look like:
Medium or Low Duty Cooking Floor
2 inches FB Board
2.5 inch thick Insulating Fire Brick
Hearth Concrete
Hmmm? Good idea, not not a good idea?
2 inches FB Board
Hearth Concrete
