Fire brick Mortar Mix question?
  • EricU
    • May 2010
    • 152
    I have poured my insulating slab and am ready to start the 42" dome construction and I have the following questions regarding the fire brick mortar mix design:
    Pics of build
    Per the Forno Bravo oven building instructions (Appendix 6. High Heat Mortar) and from the forum the Fire Brick Mortar mix is;
    1 part Portland Cement
    3 parts Sand
    1 part Lime
    1 part Fireclay
    I am using a product by HC Muddox labled ?Mortar Clay? and the bag has the following mix instructions;
    1 part Mortar Clay
    2 parts Portland Cement
    6 parts Sand
    With NO additional Lime.
    Should I use the FB mix instructions with the HC Muddox Mortar Clay?
    Or should I follow the mix instructions on the bag?
    Thanks for any help, Eric
    Thanks, Eric
    My 42" dome build pics in Napa
    My build thread part I
    My build thread part II
  • fxpose
    • Jul 2009
    • 942
    Re: Fire brick Mortar Mix question?
    I used the Forno Bravo ratio with the HC Muddox Mortar Clay.
    George
    George
    My 34" WFO build
    • EricU
      • May 2010
      • 152
      George
      So, just to be clear, you used (hopefully with no problems) the following;
      3 parts Sand
      1 part Lime
      1 part Fireclay with the Fireclay being HC Muddox product labled ?Mortar Clay? right out of the bag?
      Thanks Eric.
      Thanks, Eric
      • fxpose
        • Jul 2009
        • 942
        3 parts Sand
        1 part Lime
        1 part Fireclay with the Fireclay being HC Muddox product labled “Mortar Clay” right out of the bag?
        Thanks Eric.
        Yes, that's exactly what I used and ignored the instructions printed on the mortar clay bag.
        George
        My 34" WFO build
        • fmottahe
          • Feb 2011
          • 4
          Are you suggesting that Muddox "Mortar Clay" mentioned in this thread can be used in place of FB high temp water resistant mortar? There is a very large price difference.
          Regards,
          • fmottahe
            • Feb 2011
            • 4
            Are we saying using Muddox Clay Mortar mixed properly is equivalent to using FB high temp, water proof mortar?
            Thanks,
            • GianniFocaccia
              • Jun 2009
              • 1645
              Eric and fmottahe,
              If you haven't had the pleasure of reading thorugh this high-heat mortar primer, I invite you to do so since it answers the questions you will most likely ask next, plus gives an idea of what other builders have done.
              Personally, I couldn't see paying $90 for a $50lb bag of HeatStop 50 when I could "roll my own" as Les calls it. Like many other builders, I picked up 50lb bags of HC Muddox Mortar Clay, hydrated lime and Portland cement. I also had 400lbs #12 fine silica sand given to me. Total investment: about $30.
              I started with the traditional FB 1-3-1-1 ratio but started to ease back on the portland just a tad since it was reported this is what burns out at temerature over time. I didn't have the guts to go all fireclay and sand like Francis, but I figure my oven will outlast me. I haven't noticed a difference in mortar integrity. This mixture is a joy to use and it's ease of application is one of the primary reasons I'm milking this build and spending every weekend minute I have working out in the backyard manicuring bricks and drinking beer.
              • AnthonyW
                • Feb 2011
                • 6
                Hello - I am planning to build my first oven this spring. I have been gathering supplies and refining plans since October. I purchased a couple bags of FireRock Mortar Adhesive from a block company. Is anyone familiar with this product? Will it work as mortar for the oven?
                Thank you!
                Anthony
                • whowaaa
                  • May 2011
                  • 1
                  use fire clay 1 to 2 cement and 3 sand...you need NO LIME it takes the place of lime...
