vermiculite
  • ddonald
    • Aug 2010
    • 8
    vermiculite
    I found a very reasonably priced source for vermiculite. It is some distance away. The company says they use it for packing material and it reads No. 4 on the package. I can't find anything on the internet indicating just how large size No. 4 is.
    Does anyone know the answer to this and is it suitable for the portland/insulation layer.
    thanks,
    Dave
  • GianniFocaccia
    • Jun 2009
    • 1645
    Re: vermiculite
    This chart doesn't indicate grade either, but my guess is the Premium grade (presumably #1) would be the most expensive. The vermiculite I bought didn't have particularly large particles, nor were they super fine. Somewhere in the middle I'd guess. Have you checked HD?
    Vermiculite Grades
    • ddonald
      • Aug 2010
      • 8
      Re: vermiculite
      HD has 2 cubic foot bags for $19.97. I can get 4 cu. ft. of No. 4 for $13.
      Dave
      • leckig
        • Aug 2009
        • 99
        Re: vermiculite
        4 cu ft for $13 is what I paid. Get about 10 bags if you insulate both the dome and the hearth with it. Maybe the guy can open a bag and describe the size to you, the bigger the better. I had one bag of a very fine vermiculite and it was very easy to work with but I dont think it insulates that well
        my own Quest for Fire:
        http://www.flickr.com/photos/leckig/
        • md.guthrie
          • Nov 2009
          • 6
          Re: vermiculite
          Normally Perlite is cheaper than vermiculite. I just purchased 45 2 cu.ft bags for approx. 17 $ per bag
          • fxpose
            • Jul 2009
            • 942
            Re: vermiculite
            Let me get this straight. You paid $765 for vermiculite?
            If they were used solely for insulation purposes you would have saved money using ceramic boards and blankets instead.
            George
            My 34" WFO build
            • md.guthrie
              • Nov 2009
              • 6
              Re: vermiculite
              Did both. I want to retain maximum heat...... Trying to get it right the first time...
              • leckig
                • Aug 2009
                • 99
                Re: vermiculite
                man... nearly $800 on vermiculite. This is about half what I spent on the whole 42 inch oven.
                • ddonald
                  • Aug 2010
                  • 8
                  Re: vermiculite
                  My No. 4 vermiculite finally came in yesterday. It was $13/4cu. ft. bag. The pieces vary greatly in size with the largest about 3/4 x 1/2 in down to quite small pieces.
                  Now the question is: at what ratio do I mix it. I see blogs using 1:6 up to 1:10.
                  Is there an ideal ratio? Any tips on mixing and finishing would be greatly appreciated.
                  Dave
                  • leckig
                    • Aug 2009
                    • 99
                    Re: vermiculite
                    for under the hearth insulation you do 1:5 - because of the weight that will sit on it. I very much recommend you buy the insulation board as well, I wish I did.
                    For dome insulation: the less cement the better, but less cement you put in the mix the harder it is to apply. Most people do 1:10. The way I did mine was also 1:10, one day I piled up about 6 inch layer on the dome about 12 inches high, I let it set for a day and I continued the next day all the way to the top.
                    When I tried to do it all in one day it was always falling down.
