Jim's build for the common man
  • #16
    Re: Jim's build for the common man
    THanks for everyone's inspiration. I've also been inspired to make the next level of blocks more level. Just got a trowel, hopefully that will work better than my garden shovel. Back to work on it tomorrow.
    Here's mine:
    http://www.fornobravo.com/forum/f8/j...man-15992.html
    • #17
      Jim,
      I hope you are having as much fun as I did...I look forward to more pictures and don't sweat it, except for a few none of us were masons either
      Peter Kraemer
      Member WFO-AMB=WW
      • #18
        The old surveying tools and stories are really cool. My father in law was a carpenter and I have a few of his old tools as well as his stories of the pre-power tool days....For the record after he got power tools he never looked back and never used a hand saw again. I thought he was going to have a heart attack when he saw me using a hand saw rather than a reciprocating saw he had given me.
        Jim - I cantilevered my hearthslab with no problem and I have a lot of weight on it. I did it to gain the space under the counter. It extends out about 9'' on the left side and is supporting a full brick wall. Just be sure to "beef up" your rebar. I used 1/2'' 90's with one end stuck down in the block cavity.
        Scott -
        My projects: http://www.facebook.com/#!/scott.kerr.794
        • #19
          Scott-
          How close to the edge of the cantilevered form does the rebar have to extend to? In other words, if the slab extends 5" off the edge of the block, should I put rebar that extends 4" from the block?
          Here's mine:
          • #20
            You want your rebar between 1/2'' to 1'' from the edge of the form. If the edge will be exposed when finished then I would go more for the 1'' to be sure you have a good bond with the concrete and won't have any exposed rebar. I also ran a 1/2'' piece between the 90's out over the cantilever part and used 3/8'' everywhere else.
            Scott -
            • #21
              Also bending 1/2'' rebar is not easy. You can heat it with a torch or just order 1/2'' 90's from a masonry supply store. Or just keep it all straight and dont' put them down into the block cells. I came across these left over at a construction site. I believe you could also get by with 3/8'' and just double them up.
              Scott -
              • #22
                Well, I'm certainly not going to win a Fornobravie (name of award I suggest they have every year) but this is a grand experiment for guys with no experience, and little time. My foundation slab was not level, and I had trouble leveling the first course. I thought it was good enough, but as I went up, many blocks wobbled when I stacked them, so I had to use mortar the whole way up. The back corner ended up with the fourth course about 3/8" higher on one side than the side meeting it at 90 degrees. But rather than redo everything, and never get anything done, I'm pushing ahead. Despite the big flaws, I gotta think this will still last at least 15 years.
                Here's the latest pic - not quite done with the fourth course - gotta finish leveling and stacking one side, then grind down blocks over the angle iron spans. (Note my son's beautiful chalk drawings all over.) I got the angle iron from an old bed frame, seems like it will work very well. My goal is to make the form and pour the hearth slab and cores before it gets too cold, which I'm sure I can do. I don't think I'll be able to finish the dome before then, so I may have to put that off until spring. Or is it okay to leave exposed supersol if I start the dome, but don't finish before it snows? Can I just keep it covered with a tarp if I start and don't finish?
                Here's mine:
                • #23
                  I think as long as you leave it covered, it'll be fine. It takes forever to drive all the moisture out of the insulation board just from the construction process, so drier is better but doing the best you can should be fine.
                  Really, there is no reason you'd need to bother grinding the blocks over the angle iron. Set your formwork for the hearth slab and you'll see why...it'll have no effect on the finished surface or slab to leave them as is.
                  • #24
                    Well, my blocks are all stacked. I'm not so sure now about my prediction that the thing will last at least 25 years despite the imperfections; there's several horizontal gaps between courses of 1/8", and a few at 1/4". So I suppose the blocks could crack pretty soon under the weight of the slab, then the oven bricks will shift. Still, I say throw caution to the wind, and get this thing built. If the oven collapses, I'll bite the bullet and have a pro make a new stand, and I'll buy a FB oven. Or maybe I'll just start all over again. Next step: make form, pour slab and cores (having a truck deliver the concrete.)
                    Here's mine:
                    • #25
                      Tuck the cracks and move on, it ain't no big thang.
