Mineral Wool/RockWool
  • Jimney
    • Sep 2012
    • 40
    #16
    Re: Mineral Wool/RockWool
    Are people using this in place of the ceramic fiber blankets right on the brick dome?
    • stonecutter
      • Jun 2007
      • 2003
      #17
      I do. It's not on par in for inch with ceramic, but it does a great job, is easy to find and is very cheap. In tandem with loose fill insulation like perlite or vermiculite I see zero difference between the ovens I insulated with mineral wool vs the ceramic.
      Old World Stone & Garden
      John Ruskin
        • 9213
        #18
        I've found the main difference is that the rock wool is far more water absorbent than ceramic fibre- a disadvantage. The ceramic fibre cuts and bends better- advantage. You just need to weigh this up with the price difference and availability.
        • azpizzanut
          • Aug 2010
          • 397
          #19
          Hi All,
          Wow, it's been a long time since my last post.
          Mineral wool is an alternative to consider for insulating an oven. I have two ovens and one is insulated with mineral wool. Why did I consider mineral wool? It was cheaper than ceramic fiber blankets, available locally, and did a good job. I had no problem cutting and fitting the pieces to fit the shape of the dome. If you have ceramic blanket easily available then by all means use it. I found it expensive.....this fact is not a consideration for some. I don't begrudge them their financial status or ability to obtain the finest and latest state of art products for their oven project. Consider though, the products that insulate ancient ovens...successful ovens, of the past. Mineral wool works and so does other types of insulation including wood ash, perlite, vermiculite and others.
          The important thing is to insulate your oven well. Both of my ovens have 4 inches of either perlite or vermiculate over the dome. The dome is covered with mineral wool on one and ceramic fiber on the other. Imagine a box with an internal dome (covered with mineral wool or ceramic fiber) and that is covered with loose fill of perlite or vermiculite. That's my ovens. With all of that, does it really matter what I used to cover the brick dome (ceramic blanket or mineral wool)? Some will say maybe it does, but my ovens will still be hot three days later if I cover the door opening (mineral wool or hi-tech ceramic) be darned. Use what is available and what you can afford. Be confident that what you use is adequate and make changes later on your second oven, or third, or other. Golly, you should see what passes for a pizza oven around here and they all seem to cook adequate pizza. Dont' stress over it.
          Cheers,
          Bob
          Bob
          • stonecutter
            • Jun 2007
            • 2003
            #20
            True, mineral wool is more prone to water absorption. But if your insulation is absorbing water, then the problem isn't the insulation...you have a weather proofing problem.
            In other words, if you dry out, then dry in the oven properly, water absorbtion isn't a factor.
            John Ruskin
              • 9213
              #21
              If you live in the tropics, for certain times of the year everyone has a weather proofing problem. Sometimes in really humid weather clothes will go mouldy in the wardrobe.
              • stonecutter
                • Jun 2007
                • 2003
                #22
                Arizona is far from tropical.
                Here in SC we are subtropical, do I know what you mean. What areas of the oven get moisture intrusion? The entry would be the only obvious area, everywhere else should not get much, if it's built properly
                John Ruskin
                  • 9213
                  #23
                  Yes, I think the entry is the main problem area, although I'm also sure the porous refractory picks up moisture from the air in very humid weather (for those oven owners in the tropics), especially if the oven is not getting much use at this time of year, even if the oven doesn't get wet. I've seen lots of igloo style ovens, including those commercially available, that do not have any seal between the flue and the outer shell. Any water hitting the flue pipe will simply run down the pipe and into the entry area, then spread throughout the oven via the porous refractory and if any excess, will just settle under the floor. Another problem area in an igloo style oven can be where the outer shell meets the supporting slab, for an igloo style oven. With plenty of use after a couple of years a crack sometimes develops here and water entry at this point can occur. If the oven has not been built with a slight slope downwards on the supporting slab towards the perimeter then water entry here into the under floor insulation can be a problem.
                  • stonecutter
                    • Jun 2007
                    • 2003
                    #24
                    No argument here, brick and stone will absolutely absorb moisture from atmospheric surroundings. If we had tropical conditions here, I would have a removable outer door with a weather seal on it. As far as the chimney, I have idea on how to weather seal that too...it would have to be a double insulated boot.
                    I think the easiest problem to solve is your cold joint between the outer shell and structural slab. A flexible flashing membrane can be installed over the insulation, lapped at least 3" on the seams and minimum 3" up the side of the oven. Also, the membrane should be inserted into the structural slab by cutting a 1" deep slot around the perimeter, and caulked after tucking in the membrane. When the stucco is applied, it would hide the flashing.
                    John Ruskin
