Hey All,
Have been a guest on these forums for sometime now and have finally decided to go for it.
Rather than going for the standard concrete/brick base im planning to have a full frame welded together. Once thats completed i plan on covering it with compact laminate (LCL) in a brushed stainless colour.
The frame will also include a bbq and a bar fridge recess. I have attached a draft with a rough outline of how i want it to look.
The setup will be against the fence on the side of my patio area and this beings forth my question.
The furthest i want the frame to stick out would be 1.5metres (4.92 feet).
Q1 - So what would be the suggested width so that i can utilize more space for the kitchen prep area?
Q2- The metal framework will contain a floor/sidewalls so that i can poor concrete directly into it.. do i still need a concrete base or can i skip directly to the vermiculite? If so how thick of a layer is recommended.
Q-3 What is the recommended height if i plan on building a 36-42inch pompeii. 900mm will be my bbq/prep area, im presuming it would look better if it was all the same height. Is this high enough?
Apologies if this is all been asked before.. which im guessing it has..
Regards
Chris
Regards
Chris
