length of doorway and flu diameter?
  • sonomacast
    • Jul 2006
    • 150
    Today I cut all the forms for a cast modular oven. I have decided to make it 1050mm (41") in diameter. 472mm dome height (18.5") with a door opening of 297mm (11.6") High. The doorway is a complete arch 558mm (22") wide. The vent landing is 610mm wide (24")
    Basically the dome height is 90% of the radius of the oven floor and the door height is 63% of the dome height. All walls are 75mm thick (3").
    Now my query is this. What diameter should my flu be for a 1050 (41") Oven and what would be the best length of the landing?
    Thank you
  • sonomacast
    • Jul 2006
    • 150
    Re: length of doorway and flu diameter?
    Is it correct that the correct flue size is 10% of the door size squared.
    eg, my door is 22" x 11.6" = 225.2"square. so my flue should be 22.5" square= a flue of 5".......................Is this correct?
