Instead of firebricks?
  • tx-shane
    • Feb 2011
    • 6
    Firebricks are expensive, so I wonder about alternatives. I can get "extreme-temperature cement" and use it to cover an oven floor of regular bricks for a slim fraction of the cost of firebricks. Is this any good?
    I've also found a "refractory sealing compound" that's made to "renew the high-temperature resistance and performance of worn firebrick." So, if I've got 3-6 inches of sand, then regular bricks, then the extreme-temperature cement, then the refractory sealing compound, would that not be a suitable oven floor?
    Basically, what's the cheap and effective way around spending $250 on firebricks?
    Thanks!
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Instead of firebricks?
    Old Common brick. Austin commons , Thurber commons, Ferris brick, Corsicana Cherry Reds, and D'hanis commons will all work, but may cost almost as much as firebrick.
    I don't know that I would recommend a castable for the hearth, and they are not cheap anyway.
    • Tman1
      • Aug 2010
      • 346
      The one thing those bricks that TS mentioned, they are clay bricks (I assume), not concrete. You can get away with a different type of brick, but it won't last as long... with that said, it's probably still a good way to go. When I take my temp one apart, I'm just going to use those. I found mine on Craigslist... $50 for 600!
      My oven (for now):
      http://www.fornobravo.com/forum/f43/...ven-14269.html
      • Tscarborough
        • Oct 2009
        • 3341
        Yes they are all dry pressed clay brick. They are all also low fired (except for the Thurbers), and were produced using almost the same clay bodies as firebrick.
        • tx-shane
          • Feb 2011
          • 6
          Thank you for the advice on useable bricks. Since I'm designing a cob oven, I have wondered about simply building the oven floor out of a thick layer of cob. I will use powdered Hawthorne fire clay as the clay component to my cob, by the way.
          Off-topic: What's the consensus on the clay/sand ratio?
          • Lburou
            • Dec 2010
            • 1165
            I'm going to have a few bricks leftover....Where are you?
            Lee B.
            DFW area, Texas, USA
            • tx-shane
              • Feb 2011
              • 6
              Lburou- I live in Temple, so not real close. My in-laws are in the Ft. Worth area, though, so it's possible I'd be visiting up there before long. Your oven sounds pretty cool. I'm going to try a sort of double chamber cob design with a chimney, maybe fashioned after a snail or something goofy. I'm determined to have fun with the process.
              • Tscarborough
                • Oct 2009
                • 3341
                Drive to Elgin, you can get #2 firebrick for less than a buck (I think is is .45 Cents) at the Elgin-butler plant.
                • Lburou
                  • Dec 2010
                  • 1165
                  You have a PM with contact info and Tscarborough has some good advice aabove
                  Lee B.
                  • RTflorida
                    • Jan 2007
                    • 1446
                    I'm with Ts on this, I have to believe any bricks + extreme temp. cement + refractory sealing compound will cost nearly as much as the firebricks. If you are doing a cob oven, wouldn't you only need enough firebricks for the hearth? That shouldn't cost anywhere near $250 unless you live in Australia, where firebrick is worth more than gold.
                    My cost on 215 firebrick was $165.55 for the whole oven. The cost has since gone up but the same supplier is still only $.97 per brick. I would make a few calls to brickyards kiln/refractory suppliers, I'm sure you can find light or medium duty bricks for a $1.50 or less each. Trying to use that high temp cement and a refractory sealer is untested territory for everyone here, so I think you are totally on your own if you choose that route. Good Luck, whichever route you take
                    RT
                    • tx-shane
                      • Feb 2011
                      • 6
                      Wow, these are some very helpful comments. Although I like the idea of forging into uncharted waters with the cement and sealer, local cheap firebricks gets me even more pumped up. Is there a strong oven community in Texas, or are we just over-represented in this forum?
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        They are $1.50 in Austin, probably 2-3 in Temple.
                        • GianniFocaccia
                          • Jun 2009
                          • 1645
                          RT - Slight modification on firebricks in Oz: They aren't worth more than gold, they just cost more than gold...
                          • 123456
                            • May 2019
                            • 1
                            I know this post is old, but I am having trouble sourcing firebrick for less than $6 per brick. Where would I find the type of brick required? Are they available at stores like Home Depot? Can anyone share links?
                            • RandyJ
                              • May 2010
                              • 1191
                              Have you tried contacting a company that does boiler repair work? That is where i got mine.
                              Randy
