Flat roof or total dome
  • sonomacast
    • Jul 2006
    • 150
    I have just read somewhere that the perfect oven has a flat roof which only curves on the edge into the wall as opposed to a semi circle type. Is this true?
  • shuboyje
    • May 2009
    • 406
    Re: Flat roof or total dome
    That is a very touchy subject around here as most people have pretty standard Pompei ovens with hemispherical domes and love them. That said the traditional shape of a pizza oven is a low flat dome. A cast oven like you are planning eliminates the main issues builders have with flat domes from brick...they are harder to build and need horizontal re-enforcement to make them structurally strong.
    • sonomacast
      • Jul 2006
      • 150
      Yes I have just found on this site that the best dome height is 40.3% of the diameter which would make it somewhat flat. My brick oven was a semi circle and cooked a treat, i guess it is all too easy to get anal about all these dimensions and percentages. But I want to get it just right, thanks again
      • mklingles
        • May 2010
        • 93
        You might want to look at this post. I've recently done some calculations and think they demonstrate that the radiant energy from a flatter dome is somewhat more even on the floor but only minimally so.
        http://www.fornobravo.com/forum/9/ma...tml#post107059
        My oven build: http://www.fornobravo.com/forum/f8/m...and-13300.html
          The world is full of flat roof pizza ovens. Stroll down to the corner, to that shop that says "pizza". Flat as a pancake.
          We want something a little better.
          • Tscarborough
            • Oct 2009
            • 3341
            Realistically, unitized masonry ovens are built in a dome shape because that is the best shape with which to build them. If the oven is not a compression structure, then that part of the design doesn't really matter that much, or all kitchen ovens would be round and domed, low or otherwise, I would presume.
            • brickie in oz
              • 3445
              Originally posted by dmun
              Flat as a pancake.
              Pizza surely?
