Hi,
Slight problem. The only firebrick supplier I can find can either get me High Duty brick (68% alumina) or insulating firebrick. Medium duty not available.
I read here Brick Oven Design | Choose the Right Brick Oven Brick
That both of these bricks are to be avoided, but since they're my only option, what should I do?
If it helps, I'm building a high powered electric oven (I live in a 30th floor flat, so wood-fired is impossible, sorry!).
Cutting them is my main concern, does anyone have any experience with this? I've read that using a saw wouldn't work. Would I be able to hand-cut with a chisel, or are the bricks simply too hard?
Thanks in advance
Thanks in advance
