Hi everyone,
I am currently building my first wood fire bread oven. I have lots and lots of experience working with stone but the things I need to learn to take into account for a wood fire bread oven seem overwhelming, e.g. making the structure strong enough to withstand enormous temperatures and also how to maintain high temperatures.
I am making the wood fire bread oven with a beehive appearance (see attached graphic drawings of the front and cross section) although the oven will ne a dome. The exterior structure will be natural rock and normal cement, while the oven itself will be made from these Spanish refractory bricks and refractory cement.
My question is... Is there a danger that the temperature will get so high on the outside of the refractory bricks that it might crack the natural rock and normal cement that the refractory bricks lie immediately next to?
One person I asked said "in normal operations the outside of the bricks will not get hot enough to crack stone under the hearth but other places like near the chimney where all the hot gasses pass over could get too hot." In which case would you advise I build the chimney out of refractory bricks too? I was just going to use a normal metal chimney tube and surround it by a normal cement mix (see images below to get an idea).
Any help would be greatly appreciated!
Leao
Leao
