I'm trying to understand the easiest way to mix cement for the non-refractory areas of my oven structure. Can I use Quikrete with just water? Bread Builders and most other things I read all talk about mixing cement with sand, aggregate, etc. I don't mind mixing, I'm just trying to figure out what I need to buy. And is this the same for mortar and the solid concrete hearth slab?
Paul
Paul
