I read in the FB-provided build instructions that a 3" gravel base is recommended, with a 5.5" concrete slab atop it. Ideally, 2-3" of the slab would be above ground level. The recommended reinforcement is a rebar frame with standard wire screening suspended in mid-slab by brick pieces.
I live in northern Ohio -- is 3" gravel depth good?
Is screen the best concrete reinforcement...I see a lot of people using 100% rebar for base reinforcement.
My slab size will be roughly 68" x 52". It will support a Primavera 70 oven (yeah, I know...I could have bought the FB base instead of building one...but I'm just not a fan of the look).
I have dug the hole (6" deep, rectangular), so I'm either pouring cement on Saturday, or digging a deeper hole.
You are in good shape.
