1. I am ready to place my floor over the 2" fb board which does not have real even seams, some minor differences. Do I spread the sand clay mixture over top of the fb board to level the surface or under the fb board?
2. I have read so many posts on the homemade mortar mix that my head is spinning. The local masonary store said to use 3 sand, 1 portland, 1 fireclay and 1 lime. I have not read these ratios anywhere but they are close to all the different ratios I have seen on the posts.
I may just use the premixed (expensive stuff) for the initial setting of the dome and spread the homemix over the outside to fill in the large spaces of the outside of the dome. They say not to use the premix for larger joints.
I just want to do this right.
