I am building a Pompeii pizza oven 15 ft from my house. My permit was turned down because the international fire code defines pizza oven as a recreational fire. It actuall defines a recreational fire as anything that is not contained in a fireplace, firepit, BBQ etc. Anybody have any info, suggestions ??? I am going to appeal this decision but I need some good info. Here's reply
Mr. Cooper:
After reviewing the installation instructions available from Forno Bravo ? the manufacturer of the oven you are proposing to construct ? I have determined the following:
A chimney system will be required (See page 11 of the instructions) http://www.pizzapizzan.com/oven%20plans.pdf
International Fire Code 2009 (IFC) defines recreational fires as ?[a]n outdoor fire burning materials other than rubbish where the fuel being burned is not contained in an incinerator, outdoor fireplace, portable outdoor fireplace, barbeque grill or barbeque pit and has a total fuel area of 3 feet (914 mm) or less in diameter and 2 feet (610 mm) or less in height for pleasure, religious, ceremonial, cooking, warmth or similar purposes.? The construction of a pizza oven as you described fits this definition. Therefore the requirements of IFC 307.4.2 shall apply.
IFC Section 307.4.2 requires recreational fires shall not be conducted within 25 feet of a structure. Therefore I would not approve your proposed pizza oven to be constructed where indicated on the submitted site plan (14 feet from the structure).
Mr. Cooper:
