floor insulation options
  • jimkramer
    • Jun 2009
    • 143
    It seems these are the most readily available options for insulation below the cooking floor (besides Vermicrete, which I will not be using):
    FB Board
    SuperIsol
    Insblock (did I get the name right?)
    Are there any other options ? Which one did you use? Are you happy with it? I'd like to call it a day and get the FB board, but the shipping to NY is expensive.
    Here's mine:
    http://www.fornobravo.com/forum/f8/j...man-15992.html
  • Tscarborough
    • Oct 2009
    • 3341
    Re: floor insulation options
    Foam-glass.
    • Neil2
      • Oct 2006
      • 1374
      4 inches vermiculite 5:1 portland cement mix.
      This will be the least expensive and probably the most commonly used option.
