I have been trying to decide on the location to build my oven. I have a tiered retaining wall around a paver patio. I have included a couple cross sections of our wall and a couple pictures.
Ideally, I think the best location is to build the block stand in place of a section of the front retaining wall. However, the block stand would then have to function as a retaining wall.
In the section where the second (back) retaining wall tapers to one course of blocks, can I remove a section of the front retaining wall, build a floating slab, and build the stand using blocks in front of the back wall?
If so, can I leave the back wall alone, or might I have to rebuild it so that I have four rows of block? The overall height elevation is probably close to 36".
