As a newbe, thanks for the feedback, suggestions, and encouragement that got me through some rough spots in pouring my hearth. Great forum!
I made some mistakes and still have some issues with the vermicrete pour on top of my hearth. I will share my experiences in case it helps anyone else working with vermicrete.
I built a 7 1/2" form with the intention of pouring 3 1/2" of rebar reinforced concrete for strength with 4" of vermicrete on top of it for insulation. Instructions called for 1 90# bag of Portland and 8 cu feet of Vermiculite. Mixing procedure was dry mix Portland and Vermiculite 5:1 then add water to bring to consistancy of oatmeal.
First problem was I ran out of materials 1" short of the top of the form. Also after 4 days of drying the surface was very inconsistent with some hard spots, some spots soft to the touch and some spots very crumbly. First two photos below show the surface condition.
I got some feedback from the forum on possible next steps and then found an old post from cvdukes dated 4-12-08 on a different procedure for mixing vermicrete. Bought another bag of Portland and 4 cu feet of Vermiculite to make a second pour to finish filling the form.
Used new mixing procedure of filling bucket 2/3rd full of portland then adding water to about the top. Mixed using a drill mixer to make a slurry. Dampened the Vermiculite in a wheelbarrow then added the slurry and mixed VERY well. I felt like some of the surface crumbling may have been caused by making the mix too wet so I made my oatmeal dryer. Seemed like the excess water was washing off the cement and leaving just vermiculite on the surface.
Just finished the final pour and it "looks" good. The consistency and color of the mix looks like the cement has coated all of the vermiculite. I will know for sure in a few days when it sets up and I can judge how crumbly it is.
If I were doing this again I would probably pour concrete around the edges and just put the vermicrete under the oven.
