Insulating Blanket
  • Yahoo-Archive
    • Mar 2005
    • 239
    Insulating Blanket
    I am posting this in both places -- here and fornobravo/forum, where
    we will make it sticky.
    Using a ceramic insulating blanket is a good idea, for both brick
    ovens and refractory ovens, because they are efficient, don't use a
    lot of space, and keep loose insulation from ever getting into your
    oven. And they aren't that expensive. Would folks agree with that?
    Unless budget is a serious issue, you should consider using it. (We
    include a large 6#, 1" blanket as part of our refractory ovens.)
    If you are looking for a place to buy a ceramic insulating blanket,
    contact randy.muchow@thermalproductsco.com. They are in Atlanta, and
    ship UPS. Tell them to give you the price for Forno Bravo customers.
    If you find a better source, or a good regional source, let us know.
  • Yahoo-Archive
    • Mar 2005
    • 239
    Try this E-bay seller.* He is in*Portland *He has some interesting stuff*regarding refractory materials and blankets
    *http://stores.ebay.com/HIGH-TEMP-REF...eNameZl2QQtZkm
    Noel
    • Yahoo-Archive
      • Mar 2005
      • 239
      hi james,
      o.k., i am sold on using a insulating blanket, but how much
      pumice/vermiculate insulation can we save that way ?(what would be the
      ratio, e.g 1inch insulation blanket equals 3 inches of vermiculate as
      an example???)
      i really would like to have a super insulated oven, yet like to get
      down in thickness..., since i also like to have as much space on the
      side of the dome for putting things down while using the oven.
      --simone
      • Yahoo-Archive
        • Mar 2005
        • 239
        The rule of thumb is 1" blanket and 4" vermiculite. I had an insulation engineer run a test, and conclude that the blanket replaces 2" of loose vermiculite. We had them run a simulation where they added 1" of insulfrax, and reduced 1" of vermiculite. 1":4", 2":3", etc. over a 24 hour 1000F exposure. The outer face tested consistently dropped by adding 1" more insulfrax and 1" less vermiculite.
        1" Insulfrax Blanket 6#, 4" Vermiculite 1000F** 172F
        2" Insulfrax Blanket 6#, 3" Vermiculite 1000F** 161F
        3" Insulfrax Blanket 6#, 2" Vermiculite 1000F** 151F
        4" Insulfrax Blanket 6#, 1" Vermiculite 1000F** 142F
        5" Insulfrax Blanket 6# ******* 1000F** 135F
        Thinking about it, I should ask him to add 1# insulfrax, and drop 3" of vermiculite and re-run the test. I would note that after 24 hours of 1000F, (which you will not approach), the outer face is barely warm.
        I agree that you want the oven well-insulated, but think that you have some wiggle room. My oven here has 1" of low-tech blanket insulation (I don't even know the name of it, but it can't be close to Insulfrax in efficiency), and 2-3" of vermiculite, and I have never felt heat in my stucco walls. This is an extreme example -- I did it intentionally to see how it would work, and I think we can take a small lesson from the experiment.
        Long answer to a short question -- but some interesting background info.
