Pouring hearth Qs
  • sclancy
    • Mar 2012
    • 93
    Pouring hearth Qs
    I have the "std" 4 course high block base. It has already been covered by stone veneer. Yes, I know the timing was off but I really had no choice. I have spent hours reading posts and answered all but these few Qs...
    1. Given that I already have the stone veneer on the block, can I rip my 2x6s down to actual 4" and set them on top of the block as my forms rather than "attaching" them outside the block? The 4" slab will then be recessed back approx 2" from the edge so that I can then add veneer to the edge of the 4" slab....Are we comfortable with the slab sitting on about 5 1/2" of the block all the way around?
    2. My block was built by a mason and pointed the old fashioned way. I plan to fill every other hole with concrete when I pour the hearth. Is rebar down the holes necessary?
    3. I have a sheet of durock leftover. I plan to use this for the underside of the hearth pour. Is it better of worse than plywood? Do I remove it after the pour or just pull the wood supports and leave it in place?
    4. Can anyone point me to pictures of the wood framing that is recommended to support the hearth pour in the center?
    thx
    Sean
  • Laurentius
    • Nov 2010
    • 923
    Re: Pouring hearth Qs
    Pompeii Oven Plans2.0
    • Ken524
      • May 2007
      • 1655
      Hi Sean,
      Welcome to the forum!
      1. I don't see a problem with your "recessed" plan. I think it'll work just fine.
      2. The plans are designed for beginners who dry stack the blocks. If you had a pro build your block stand (mortared & pointed), you are ready to go; no core filling or rebar is necessary. Stuff some trash and debris into your cores so they won't fill with concrete when you pour the hearth. If you want some extra insurance, feel free to throw some concrete & rebar in the corners.
      3. Durock is the easy way to go. Pour the hearth right on top of it and it becomes a permanent part of the hearth. I used plywood and had to cover it with plastic so I could pull it out after the pour; extra pain in the backside.
      4. Here are the pics and details of my hearth pour:
      Motivated by all the other amateur builders here who said "If I can do it ANYONE can do it", We've kicked off construction of "My Old Kentucky
      A few 2x4's braced under the durock and you'll be all set.
      Good luck with your build and post some pics for us! I'd like to see your stone veneer.
      Ken H. - Kentucky
      42" Pompeii
      • sclancy
        • Mar 2012
        • 93
        Ken,
        Thanks!! That is exactly what I needed to hear err....read..... Your build thread is fantastic. Looks great.
        I really have to decide what direction to go for the WFO.....I really think I am going to do a modular and then have my carpenter do a metal stud "house" over it....maybe even cover it with veneer stone all the way to the roof and do a black standing seam roof to match the overhangs on the house....
        • brickie in oz
          • 3445
          Is there an English translation for this?
          • Laurentius
            • Nov 2010
            • 923
            Al,
            That is English! You just don't know WTF he's talking about.
