there are a couple different trains of thought on that . one is to go down to frost line , your building dept could tell you how deep that is , pour a footer and stemwall then build your slab on that . the other is to do whats referred to as a floating slab , which is basically a slab that is poured on a gravel bed on grade . you can find good examples of both on the forums here.
