planning and layout stages
  • TylerDavis
    • Apr 2010
    • 44
    We moved into a 1970s Territorial Style house here in Tucson a few months ago. I have big plans for a WFO and Rumford fireplace, but it will probably be next summer before I can find the time to begin, with all the other house renovations.
    There is an obvious site in the backyard, I just have to figure out how to lay it out. The idea is build an L-shape slump block structure with a 36" WFO on one side and a Rumford fireplace on the other. Seating for at least 6 and an open pergola roof with vines overhead. It is a somewhat tight area to fit all this in comfortably.
    There were 6 defunct citrus trees in planter beds, each one 2'x2' inner dimensions. I may co-opt the one in the photo for either the WFO or the fireplace. The brick patio will stay in-place, and I plan to have table and chairs up there, but I can't think of a way to integrate it into the cooking area. The brick patio is raised about 8" from the ground, so I'm trying to capitalize on the sunken-seating feeling. The brick steps in front of the pool fence can't be obstructed; there is a swing-open gate right in the middle of those steps.
    So I was thinking, seating bench area over top of the old flower bed, then WFO in the citrus planter bed, and fireplace on the edge of the brick patio. Any ideas?
  • TylerDavis
    • Apr 2010
    • 44
    Re: planning and layout stages
    • Les
      • Sep 2005
      • 2945
      Any ideas?
      It looks like some of the existing brickwork is compromised. I would personally tear it all out and start with a clean palette. It looks like you have ample room to make a great kitchen...
      • brickie in oz
        • 3445
        Originally posted by Les
        Any ideas?
        It looks like some of the existing brickwork is compromised. I would personally tear it all out and start with a clean pallet. It looks like you have ample room to make a great kitchen...
        What Les said.
        • TylerDavis
          • Apr 2010
          • 44
          What Les said.
          the long planter bed is certainly failing - probably some roots/irrigation water compromised it. Agree about knocking it out and building a new bench for seating on top.
          The citrus planter bed would be nice to reuse as a foundation (just pour concrete slab right in the middle) but I'll remove it and start over if I have to
          The brick patio itself is in good shape and will stay. In fact I was thinking of building the Rumford fireplace right on top of it so it is elevated that little bit
          I think my most limited quantity will be counter prep space. I'm not sure if I'll have enough on either side of the WFO for prepping pizzas
