Re: 38" build in southern IL
If you got it use it. Be prepared, you will get cracks, it is a fact of life with these WFOs. Adds character. As I was laying bricks I did use leftover homebrew on my dome just because I did not want to waste it. Take your reading all over, your just want to make sure you do not concentrate the heat in any one place, unequal thermal expansion in one of the culprits to cracks. Are you insulating with ceramic fiber or vcrete/pcrete or both. If using vcrete or pcrete, save you cement to use there too.
