Hello,
I've been reading the forum for a couple of weeks now and am grateful for the amount of information I've been able to glean from everyone's posts.
I'm starting a 36" Pompeii in North Vancouver, Canada, and have a question about stand design.
I'm in a rental house at the moment and would like to be able to relocate my oven when I move in 1-2 years. My best idea for a relocatable oven would use a stand made out of wood so I could support the dome and remove the legs from the stand when it came time to relocate.
My idea was to use a 4x4 post at each corner with a 4x4 across the top of the 2 posts on each side, then install 2x6 joists on hangers @8" centers to span between the 2 post assemblies. I would then cut a sheet of 3/4 ply in half and fasten both sheets (1 1/2"x 4'x4') to my base. I would have to brace the legs top to bottom for lateral stability, and I thought I could use 1x6 or similar.
Questions:
Has anyone tried to build a dome on a wooden stand before?
Would the layer of vermiculite concrete be enough insulation between the cooking floor and the plywood, or would I need another insulating layer? Pavers?
Will the dome fall apart if I try to move it?
Would anyone care to comment on my potential stand design?
As this is my first attempt, I'm trying to minimize my costs so a wooden stand would also be much more economical from a cost perspective.
Thanks for taking the time to read and I'll be sure to post up photos once I get started.
Jesse
Questions:
Jesse
