Frequent listener, first time caller. I tried to post this question yesterday, but it didn't seem to work.
I have been wanting to build a wood fired oven for several years, and now is the time to get started. I have been doing extensive reading on this forum. I am sure that my expected success is entirely dependent on the builders who have taken the time to post to this forum, so thank you every one.
I am trying to decide on oven size. I am wanting to ask a question of the builders who have been using their oven for a while. If you built a 32" or 36" oven do you wish you had built a 42" one? Conversely if you built a 42" oven do you now think that it didn't need to be that big?
I started excavating last night, so this is a decision I need to make soon. Any input will be greatly appreciated. Thank you.
From my research here on the forum, most builders build the oven that they have room for. If that is not an issue, then consideration must be given to fuel cost, time for preheat, and the number of people you expect to be cooking for. Larger ovens tend to be slightly harder to work the oven and take slightly longer to heat as well as require more fuel to achieve cooking temps. I would expect heat retention to be longer as the ovens size increases because of the extra mass.
