Hello all.
I am going to start my pizza oven spring 2014. I was contemplating building a steel base structure instead concrete block and foundation for my oven. The area where my oven is going has a steep drop off and getting the proper footing would be a nightmare!
After my structure is built I will then cover it with plywood with stone veneer.
Thoughts?
Thank you to all and thank you FB for this forum!
-Tim
Thoughts?
-Tim
