BL
welcome to the forum.
There are several builds underway and completed using wood for a base. Some have incorporated wheels as well. The oven you have is listed as 450 lbs. So with a concrete base and the weight of the stand you will be around 1000# i would guess. I wouldn't be too concerned with moving it around just because of the weight. I would suggest that you consider the 250# that will be concentrated to about 1 sq inch under each of those casters. If you have a wooden deck, you will want to distribute that somehow. Many builders have done the casters and most admit it never moves after completion.
Also, have you checked out the stand that FB store offers? Cucina
Texman
