Here goes again, this did not seem to submit last time.
I have been trying to figure out how to calculate how much insulation to use.
If I use Insulating Fire-brick for example, What thickness is thick enough to fully insulate a wood-fired oven?
Specifically I am thinking that I am not really interested in heating up a few hundred pounds of bricks, so am thinking of the internal just being straight insulating fire-brick. I understand the point of the heat absorption/retaining, but would rather just have direct fire heat.
And particularly for the dome roof, it would be sooo much simpler, lighter, and cheaper to just go one straight layer. And I love the look of brick. If I just went one layer of IRB How thick would I want this, specifically for short burnings? I am not running a commercial operation here, I am really thinking a normal use case would be a few hours.
Also, it is a lot of a softer product than dense FB, so would that mean that I would not want it as my oven floor, as all the metal tools and wear and tear would damage it a little too fast? I think it is still supposed to be about normal brick strength, so it should not be too bad.
the big bonus of just fire-brick insulation is the price, if I put anything else, not only do I have to pay for that, but than probably also some a layer of normal brick (or whatever to cover it and protect it form the weather). And then it is like 3 times heavier, and I need to increase the foundation.
I understand that they can be a lot more expensive, and cost is a huge issue, but I am thinking because I might be able to significantly cut down on the amount of materials needed, it is so elegantly serves what I what for a oven, that it might work out the best for me.
what are your opinions on this?
