Bevel Cuts
  • SandySpringsPizza
    • Nov 2013
    • 36
    Bevel Cuts
    Admittedly, I'm a little thick when it comes to visualizing in 3-D, but I am confused about cutting bevels for the dome bricks. Is the bevel cut made on the side of the brick that faces into the oven?
    Some of the angles that I see for those bevels are pretty exacting. How do you correctly calculate those angles using a homemade wooden jig?
    Mark in Sandy Springs, GA
  • Les
    • Sep 2005
    • 2945
    Re: Bevel Cuts
    No, the cuts are on the sides. The interior angle is controlled by raising the back of the brick. You could cut this angle but its not required.
    Some have posted the exact angles required and built jigs to hold the brick to the angle. I just used a shim and made many trips up and down (and wasted brick) to get them to fit.
    • kbartman
      • Feb 2013
      • 572
      Re: Bevel Cuts
      Yes many trips........estimate the angle on the lesser and keep increasing till you achieve the correct angle, less wasted bricks.
      Respectfully,
      KB
      My build
      • GianniFocaccia
        • Jun 2009
        • 1645
        Re: Bevel Cuts
        I just held each brick in my hand and carefully rotated it against the turning blade in order to cut each bevel. For radius cuts I drug brick face across the side of the blade to achieve the proper depth. After cutting a few bricks' bevels on each course it became easier to just 'eye' the cuts. I was able to get by with just one pass on a good number of bricks but the majority required me to go back to the saw for a second or third pass.
        Of course this approach demands a very sharp blade or it will wobble and want to grab the brick.
        • deejayoh
          • Jul 2010
          • 1893
          Re: Bevel Cuts
          if you want guidance on beveling bricks, here are two threads with tried and true jig designs:
          Chipster jig http://www.fornobravo.com/forum/f28/...ble-16780.html
          Hendo's twist and tilt http://www.fornobravo.com/forum/f28/...tilt-2802.html
          Also, see the spreadsheet in my sig if you want an easy source to calculate all the angles
          • SandySpringsPizza
            • Nov 2013
            • 36
            Re: Bevel Cuts
            Deejayoh, I have poured over your charts and re-read your posts. How were you able to set the angles on your jig? Guesswork, some kind of angle device?
            • deejayoh
              • Jul 2010
              • 1893
              Re: Bevel Cuts
              Get one of these (what I used)
              Multipurpose Angle Finder
              or if you want to get fancy, one of these
              16" Digital Angle Level
              • SandySpringsPizza
                • Nov 2013
                • 36
                Re: Bevel Cuts
                thank you. I remember seeing that at HF.
