Forno Bravo Morrtar
  • Rogerbown
    • Dec 2013
    • 6
    Forno Bravo Morrtar
    No where can i find mixing instructions on the Forno Bravo mortar. It would be nice to have at least a starting point on mix ratio. Data sheet?
    Can someone help out?
    Tried FB customer service but no response. Not that impressed with their customer service, unimpressed actually.
  • Les
    • Sep 2005
    • 2945
    Re: Forno Bravo Morrtar
    Roger, FB sells a refractory mortar ( it's either Heat stop or ref mix, don't recall which one). If you are referring to the "self made" mortar mix, you can find it here.
    High Heat Mortar Primer
    Oh yea, be impressed - this is a great community...
    • Rogerbown
      • Dec 2013
      • 6
      i was referring to the FB brand refractory mortar, mortar that comes with their modular kits.
      • Les
        • Sep 2005
        • 2945
        The directions for mixing is on the bag - if not, got to the manufactures web site. FB does not make mortar mix.
        • Rogerbown
          • Dec 2013
          • 6
          the only thing on the bag is a big barely readable 50. i know they don't make mortar :-), it's a repackaged product. I'd go to mfg site but how would i know who the mfg?
          • stonecutter
            • Jun 2007
            • 2003
            Probably heatstop 50
            Old World Stone & Garden
            John Ruskin
            • Les
              • Sep 2005
              • 2945
              Just mix it w/ water. It's kinda like pancake mix, mix it like you want. If it's made for mason's - it's pretty forgiving.
              • kkgator
                • Oct 2010
                • 129
                Roger,
                I can't recall there being a specific mixing directions tag on the mortar when it came with my kit. Everything that I read on the forum and private help lead me to mix mine by sight and feel much like pizza dough. Not to wet not to dry. We used a mixing blade attached to a power drill added some water, mixed. Added a little more water, mixed. You want the consistency to be thick but not runny. Have you ever seen concrete poured from a truck and how wet it is? You want your mix to be a little drier than that or at least that is the consistency we shot for. Just mix a little at a time and spread that amount before mixing more because it sets up fairly quick.
                Best,
                Kenny
                • Tscarborough
                  • Oct 2009
                  • 3341
                  You add water until it is right for your conditions. There is no one answer. If you are working in 100 degree heat and it is windy it is more water than if it is 80 and still.
                  Place an amount that can be used in 15-20 minutes into a mixing container and add water until it is sticky and creamy, wetter for high temps, drier for cool temps.
                  • Rogerbown
                    • Dec 2013
                    • 6
                    Thanks for the replies! I know it varies a lot (I've mixed mortar before but I am not a mason) but it's nice to have a starting point...
