Hi everyone,
Aside from losing some insulation properties, do you think a 2 inch layer of vermiculite concrete will have enough compressive strength to support the oven etc... Made a minor height calculation error and don't want to go too high. And am trying not to spend 300 bucks on insulating board which is 2 inches thick.
I figure if it's going to hold, then I don't mind losing a bit of insulation. Can also put some sisulation under and maybe even in it to add extra insulation properties?
Thoughts?
Thoughts?
inches to mm...
