After a few years of thinking about building an oven I am now doing it. I'm starting with a cob oven because my soil is expanding clay and there is lots of it.
I've found two things that I'm intrigued by. One is an aluminum reflector dome for flood lights. It is 11" tall by 30" wide, and has a really interesting pattern of flat spots that seems intended to focus light to the center. I'm thinking of using this dome as the basis of the sand form (ie, coating the inside with wet newspaper, filling it with damp sand, and removing the dome to leave behind the shape.) The dome is not round on top. There is a flat disc the size of a dinner plate. would this shape be better or worse than a dome (which I can do by simply shaping more sand on top manually).
The second thing is a heavy steel bracket that might be used to hold 55 gallon drums? It is really sexy looking and the perfect height. I can put my cast iron dutch oven in it with room to spare. The steel arch would help support the cob in the same way a brick arch would. However, I'm worried about the different expansion coefficients of steel and cob. Would such a steel lip at my oven entry be a problem?
Thanks, I'm really glad this forum is here. It is so nice to read about everyone's oven projects.
