Hi folks,
When people speak of a 28" or a 32" oven.... is that the width of the interior cooking space or the overall exterior width?
I'm considering building a semi-portable small oven with an overall exterior width of around 28" to 30". Is this possible? Will it work ok?
This is what I'm considering:
- A treated solid pine base (using 90x90mm wooden beams - similar to in this video: https://www.youtube.com/watch?v=i0foHjPVbP4)
- For bottom insulation I'm considering a layer of 45mm Rockwool with a 50mm layer of vermicrete on top.
- For the cooking surface and entrance tunnel/arch, 5x11x22mm refractory bricks
- For the dome I'm considering using a mainly cob (if I can find clay anywhere).
I'm considering a final layer to weather proof it and for aesthetics if possible... what should I use here and how thick should my cob layer be at a minimum?
Any thoughts or feedback?
