Concrete Calculations
  • di11on
    • May 2014
    • 109
    #16
    Re: Concrete Calculations
    Thanks David, really appreciate the advice.
    I did add burn-out fibers. I cut up some polypropylene rope. Not much though, and I didn't separate the fibers very much. Nice weather here in the South of France... I might just let it dry naturally for a good while before firing up. Since mine is in sections, I could, for example, turn them upside down in the sun to dry the inside.
    Here is the advice from the Ciment Fondu website:
    It is advised that the first firing does not take place
    before 48 hours after casting. Then to carry out a
    gradual rise of 50?C/hour and holding for at least 3
    hours at 110?C before then continuing up to 500?C.
    What do people generally use to control the temperature of initial firings?
    My oven on a pallet build thread
      • 9211
      #17
      Using an alternative fuel is a very good method, but we're not allowed to discuss it on the forum. You may be able to find some good solutions on the curing thread or PM me.
      • di11on
        • May 2014
        • 109
        #18
        Thanks again Dave.
        I'm wondering, since my oven is cast in sections - would it make sense to do some curing before I mortar them together? There'd be a lot more surface area for moisture to escape.
        In this case, are there any special precautions I should take? Otherwise, I could just follow the standard instructions with my un-mortared dome and then some again once I've mortared. Would that make sense?
