I have a 60 x 60 inch concrete stand in the corner of my patio. My patio has a brick knee wall all the way around it's perimeter. Currently the knee wall only comes half way up the stand. I plan on adding more courses to the knee wall and two more walls to enclose the stand and oven, effectively making the stand 71 x 71 inches outside to outside measurement. What is the largest size Pompeii style oven (non corner install) that I can put on the stand? iI would like to to at least 3 inches of extra cladding and use 2-3 inches of FB blanket on the dome, finishing by filling the enclosure with vermiculite. The enclosure will have a gable type roof. Thanks for any comments, suggestions, or ideas in advance
Dome Size advice
Dome Size advice
______________
I talked to a calzone for fifteen minutes last night before I realized it was just an introverted pizza. I wish all my acquaintances were so tasty.
Jarod Kintz
http://www.fornobravo.com/forum/f6/n...ona-20937.html
Google + Link to my buildTags: None -
Re: Dome Size advice
Just like jeffrorrt, I too am starting up my outdoor pizza oven project myself. I have a 48x48 inch base, any info on recommendations on dome diameters and sizes would be much appreciated!
I suggest a 42" oven. NCMan told me that he'd sent his IT to you...that came from me, and previous to that, from Kurtloup! Best wishes on your build.Link to my build
http://www.fornobravo.com/forum/f8/4...nia-19904.html
Link to my pictures
https://plus.google.com/photos/10871...CPfMh4SMmcnQAQComment
Thanks! Check out my progress under New build in SW Arizona
______________
Jarod Kintz
Google + Link to my buildComment
If you have a stand and want to build a dome, here's a quick calculator:
- the oven walls are normally 4.5 inches thick so that is 9 inches total
- you'll want at least 3-4 inches of insulation. Let's say 4 so that is 8 for both sides
- you need some kind of enclosure, let's say that is 1 inch thick so 2 inches all together.
- In total that is (9+8+2=19 inches)
So the max dome size you can have is x-19, where x is the base size.
For a 48 inch stand this gives a 29 inch oven
For a 71 inch stand this gives a 52 inch oven - way bigger than you will ever need!Comment
Thanks B,
I went wih a 39 inch
Jeff______________
Jarod Kintz
